kidd gs-t
- 80
- Jul 6, 2002
hey i have a hks type-1 turbo timer and i placed it under my cd player/ right next to the cigerrate lighter/ right above my shifter. And yes a hole was cut for it for it. the problem is that it fell in. well the guy who put it in did the same on his gs-t, but he had greddy on http://www.import-performance-parts...Turbo-Timer.htm , and the design is a bit differrent then mine, it kind hooked on to the hole so it doesn't fall in. To prevent it to fall in because the type 1 is shaped differently check here http://nextcollection.com/html/ape-...e-none-none.cfm , the guy rubber cemented it on, which werked for a while... until it fell in . now my damm turbo timer is stuck inside my console and i dunno how to re-mount it. i think some sort of brace would werk, but not sure. What do u guys recommeneding?
