edscott
- May 17, 2003
Does anyone have the 2G dash bezel for 2 gauges as sold at:
http://www.turbotrix.com/images/2gbezel2.jpg
If so, how do you like it, esp. compared to pillar mounted? Is running the themocouple or vacuum line a problem with the dash? Does it block any of the stock gauges? Is it really that necessary to have the gauges at eye level like on a pillar? I'd like to reduce the attention factor that pillar mounted may have.
Any suggestions on what to go with a 97 dash? I'm thinking VDO cockpit black or vision series, they seem like a good match for the 97. Any *real* need to go with peak or non-mechanical gauges? I want to install 2 gauges - boost and EGT.
Thanks.
Thanks.
