95talontsi
- 274
- Jun 29, 2002
Princeton,
I polished these babies myself, it was a pita cause the guy painted them before.
If you ever have to deal with a painted valve cover again try using some aircraft stripper. Just spray it on and let it soak for a minute or two and you will see the paint basically fall right off of the valve cover. You may have to do it a few times to get all of the paint off but it will save you alot of time.Originally posted by 95talontsi
okay so here the proccedure
I hand sanded everything no tools
I used 40 grit paper to take the paint off
then went over in 80 grit
the to 150
then to 400
then to 800
then to 1000
cleaned it off with wd40 periodically cause alot of dirt builds up
then used mothers mag and aluminum polish it shines really nice
see sanding takes out all the scratchs and pores in the metal so when you polish it it looks smooth and shiny, mine covers aren't perfect but I wanted to drive the thing, it is hard sanding in between the letters and numbers but you can't really tell from far away.
