89-91 clear corners
I looked there, They do not have em!!! correct me if Iam wrong, maybe I over looked them.
u can easily make ur own, i did. remove the whole lense assembly from the car, and heat the seal that holds the clear lense to the backing with either a blow dryer, or a dip in hot water. this softens the silicon/glue that holds it together. once this is soft, pry open the clear lense and u will find that the orange part is infact just another lense that is resting inside. just remove this piece and u have clear corners. the only minor difference between my way and the boughten ones are that where the orange used to be will not have that ethced effect because that was achieved by the orange piece. the boughten ones have that designed in the clear portion. i hope this helps, reply and let me know how it went. if u insist one buying some look on E-bay.
ebay has none :) I dont wanna make em, I need 2 replace mine. They r cracked, so I'd rather buy clear ones.
I got mine there. They're prob just out of stock, they take down the web add until it comes back in stock. I had to wait a month to get the cf gauge bezel (from procarparts.com)
U try goin to a junk yard, and gettin some old stock ones, and makin them clear urself?
