Amps
i want to run them at there rms which is only 350... what is considered the best type of amp for that?
get a zapco amp 800w you want to over power them alittle bit so you dont distortion the sub but make sure you turn it right or youll blow the sub other good amp r extant phoenix gold kicker but a zapco or extant will be your best bet
just remember if you dont give it enough power the it will distort if you give it too much and dont turn it right it will blow make sure your gain is all the way down befor you turn the system on then turn you headunit up to the level you will most lisin to and adjust your gain from their
