blink faster.....
what you need to do....to make your signal lights blink faster:
1) find your turn signal
2) take your hand and hold the turn signal
3) shake your hand up and down really fast
presto....your signals blink faster!!!
seriously...you can go to ebay and search for 'hyper blinkers eclipse'
something around that nature and purchase them offline.
or you can make them yourself. actually. you can use the search engine here in DSMtuners and there are several threads on this topic if you need more enlightenment.
Blinkers will blink at twice the speed to let you know you have a burnt bulb. If you put the LED bulbs in, they blink fast. Something that the car doesn't reconize about those bulbs, probably the low amount of power they use.
OH the Tweaker Blinker you want, yeah its really annoying, but if you want its your decision. All you need to do is take the bulb out and and there are 2 little metal prongs that are on the bulb. one towards the bottom and one in the middle you need to shave file whatever the bottm one and put the bulb in backwards. Just push the bulb in, it will go in further, then presto Tweaker Blinker Heaven.:laugh: :thumb:
The LED bulb will do it, but it seems they burn out a lot quicker then the normal bulbs. I have gone through 2 sets in less then a year, and there are 6 lights in the tails at like $10-20 a piece, its a lot of money for lights.
Or go to the local autozone and buy 4 LED blulbs and replace them and it blinks hyper-blinker...or at least thats what i did
