Resolved Gauge cluster removal
boost_freak
Nov 13, 2007
Laporte, Indiana
i have a 95 eclipse gst and need to remove my gauge cluster..i took the 2 screws out of the bezel, now what do i do?
unscrew the four gold screws from the upper and lower side of the bezel then rock it out side by side and bammm
I believe once you unscrew the bezel out you will see all 4 screws holding it down.
Be extremely careful with installing the overlay. Did it to mine and now my temp gauge doesn't work.
Ovelays can cause a bunch of problems with gauges. It can cause the tach or speedometer to be jumpy, it can cayse any gauge to hang up at a certain point, or like said above, can cause a gauge to not work at all. Just an FYI OP.
