DSMRevolution
- 1,629
- 11
- Dec 6, 2002
Sioux Falls,
South Dakota
I have a AWD Talon and as you all know, it has a hump in the back end. This hump prevents making any kind of low (really low) sub enclosure. I have all the wood I will need (almost all at least) and I am going to get fiberglass if needed by the weekend. I have a Jensen 10" and here are the specs:
Single 10" Bandpass Sub System
525 Watts Peak Power, 175 Watts RMS
2-Port design - for deeper bass
Dual 4th order bandpass subwoofer system
Single 10" Low-Q optimized drivers
Carpeted enclosure
Plexi subwoofer viewing window
Computer tuned acoustic chambers
No crossovers needed for simplified installation
Compact design
That is all that I know about the subwoofer. Currently it is sitting on the hump in the bandpass box. I want to get rid of that bandpass box and make a false floor. But at the same time, I don't want to free air the sub so it needs to be in an enclosure. I have seen people on this board who made a false floor. I know how to make the floor and everything, but I do not know how to figure out how big the sealed part where the sub goes should be.
I would rather just make one big low profile box. Like the length of the truck but the width cut in half so that I still have room to put the amps in. In other words, It would be just one big false floor with a sub flush mounted and the amps and everything also flush mounted.
Can anybody help me out with making the specs of the sub box? Thanks
Also I know that the sub is just a sh!tty one. I just want a bit of bass and not make the car much heavier. I like the way the Jensen sounds even though it is not NEAR as good as a decent one. No flaming now
thanks again
Carpeted enclosure
Compact design
thanks again
with this...But thanks!!!!
yeah thats it. A friend of mine bought it first and it hit hard with a jensen 350w amp. I just decided to get something to make my music more interesting. The box fits fine but I want something that is more low to the floor. So thats when I decided to do something custom. Ill keep you updated with the project. Hopefully it sounds as good as it did when it was in the bandpass.
