InfiniteGSX
- 3,184
- 13
- Dec 10, 2002
Tijeras,
New_Mexico
About to make another one of my sub enclosures except this time I'm making my own box. Usually I just use a pre made box. But this time I'm making a box, perfect size for the sub. However my issue is port direction. The sub will be flat facing up toward the rear window. Port can point toward the front of the car, the left of the car, the right of the car or the rear of the car. Hell I can even make it shoot down toward the tire. Yes the box is going to be right above the spare tire, I've already made sure with the spare tire in, that I'll have enough room without killing any real trunk space vs a 2g awd stock trunk (with all the plastics that level out the trunk floor) using the specific sub I'm going to use.
And besides port direction, general side of the box, Driverside, Passenger side, Front, Rear... I'd prefer not to port up, the same direction the sub is facing. Just because I don't want dirt or tools or anything to fall in it. Which would be a royal PITA to salvage. If its best, maybe I can make some sort of port cover with a light cloth (like what you see on house speakers) to block dirt and debris from entering.
Anyway here's the box. Its a thin but square box.
Give me your thoughts. This will be my first real enclosure. Also any hints on a port. I was just going to do a wall, like a hallway that will be 6x3x19.5" in size.. Maybe less if thats too much. LMK. MDF costs a lot so I prob only have one or two shots at this.
