Boost controller placement
snipe99999
301
May 13, 2002
I really want to put my boost controller where ClutchTSI/AWD put his turbo timer. I was just wondering what people did to achieve this (brackets, what to use to cut the whole) and anything else I might need to know?
use a dremmel to cut it -- take your time , make it fit tight -- ya can use epoxy/bondo to make a bead around the back to hold it there-- if you dont want to rig up some brackets
I used a Dremel to cut mine with..Then used Hot Glue around the outside in back.Mine is also Flushed mounted.Hasn't moved or fallen out since.There a pic in my gallery.I'll get better for you tommorow during the daytime.
