dnhieu
- 1,927
- 17
- Aug 16, 2004
panama city,
Florida
alright just checked my clutch pedel and its got some play. i will be taking out the dash to replace the heater core before winter and i was curious on how much easier it would be to swap the clutch pedel with it out?
thanks in advance
david
thanks in advance
david
I've pulled 3 pedal assemblies and only reinstalled one. I've always dropped the column down and layed upside down just long enough to get a migraine, by then you should have it out. Wouldn't be a bad idea to do everything at once, but you'd have more bolts and pieces laying around, which leads to the infamous "where the hell did this go" Good luck, I'm trying to put it off till it gets to cold or I'm bored enough.
