robbndahood
- Sep 5, 2002
i know this sounds like a cheesy question, but I just bought new bulbs, and cant figure out how to install them. What is the proper way of doing it? Thanks.
robbndahood said:i know this sounds like a cheesy question, but I just bought new bulbs, and cant figure out how to install them. What is the proper way of doing it? Thanks.
By that he means the finger print you leave becomes a hotspot and your bulb can explode, this happened to me once.99gst_racer said:Also, make sure your fingers do not touch the glass on the bulb. Wear gloves if you have to. The oils on your skin could potentially cause the bulb to prematurely fail.
CanadianTSi said:The "Paperclip" is in a groove that holds it in place, just push it down and out and then you can remove the bulb.
