94 gsx to 97 conversion
lop3z_1986
Mar 16, 2005
Santa Maria, California
I am going to buy a 1994 AWD gsx and do the stage 2 power upgrade to 400 awhp or so. Now for my question, is it possible to make the 1994 gsx look like the 97? The reason is so that I can fit 1 of 2 wide body kits that I found for 97 gsx. I cannot afford a 97. Or, can I just use some sort of method(foam or fiberglass,some type of filler) to rig the kit onto the 1994 as is. The two body kits are the millenium and the other is on KrazyKustoms.com both for 96-97 GSX
:( Is there a conversion to 97 body? I have googled it and came up with $h!t.
thanks for helping.
thanks for helping.
Well, considering the posts we've given you and what google has been telling you. No. :rolleyes:
If you want the '97 eclipse body. the easiest thing to do is sell your '94 GSX and find a '95 talong Tsi AWD with a crappy body, and do the conversion.
No, the easiest thing is to buy a 97 GS-T/X that has walked, and transfer the motor from your 94 into it. Save yourself the time, money, frustration, etc.
If you want a 2g, buy a 2g. Want the 1g power, do the swap. Honestly, I don't see a reason to waste your time on something like that.
