JiveMasterT
- 1,848
- 9
- Jan 3, 2004
Chest of Westerson,
New York
Ok, so for shits and giggles, i just removed the plugs going into the stock inifinity amp in my car and turned on my car. Wow. It sounds so much better without that thing plugged in and my Alpine head unit doing all of the work. There is a problem though... the damn thing flickers quite a bit at higher volumes and if i turn it up too high it just shuts itself off i guess because it runs out of juice. my question is... how can i run a better wire to it? what kind of wire should i run and how big should it be? also, where should i run it from? im assuming the battery is the place to run it from and then i would just run that directly to the wiring harness of the head unit. Thanks in advance.
i will try to unplug them tomorrow though to see if that helps.
