97-98 Talon Mouldings. Where to buy?
You could try a junk yard, but its unlikely to find a talon ...
You could also take some from a different car (although they might nto match up exactly). Certain cars' moldings simply are stuck to the body by some glue and thus you can find any type of molding and re-attach it.
*edit*
this doesnt really help, sorry :\
the aprt on the door , goes thru the door ie holes there... the little 2" erar piece it stuck on with some sort of adhesive.
Jeep dealer can probably still get em new, best bet? Find a set of doors at the junk yard and jsut swap doors, or swap with a friend who wants the lower door mouldings instead al 96...
heh easier said than done man.
Theres not many 97-98 talons runnin around my area and MUCH less 97-98 talons in the junkyard! Probly a 10% chance that somebody has a green green 97-98 talon that wants to trade doors with me.
Maybe i could eliminiate the whole attaching through door system by cutting off whatever stud there is or shaving if necessary followed by sticky double sided adhsive just like you mentioned about the peice on the 1/4 panel. (run on sentence sorry)
Thanks for the help, dealership is the way to go then
