2 questions
Theb95tsi
131
Aug 15, 2004
Bucks County, doylestown, Pennsylvania
is there a gauge pod that fits under an aftermarket radio/cd player there is an open space to put like cds or something in but i think it would be pretty cool to have a gauge or two there..
and also for some reason my power window/door lock switches have fallen down into the door the part that is to be screwed into the power window switch some how broke off what are your suggestions to getting this back up
:talon: :talon:
Like this? No.
The bosses the retaining screws go into, molded into the underside of the cheezy plastic trim around them have cracked. You may be able to get away with using slightly longer screws, or epoxy the switch in place with JB Weld.
yes defiant it looks exactly like that
and thank you for answering my other question too
Blitz does make a DIN panel to hold a turbo timer/ebc and one gauge.
It is pretty common for the switch panel to break through the plastic anchor underneath. Like Defiant said you can sometime get away with longer screws to get down to the unbroken plastic or you may have to be creative with epoxy or jbweld.
