My system, opinion..please
TotalEclipse98
204
May 19, 2002
Alright, i talked to this guy Carlos from celica.net (since i have a celica) and he works for a warehouse and is getting me some good prices some more expensive but with 2 year warranties instead of 90 days...here is what i am getting..
-Alpine CDA 7894 ~$345
-10gauge rockford fosgate wiring for headunit straight to battery ~$20
-Front Components for both doors ~$160
-Upgraded Speakers for the back ~$80
-Two 12"s Fosgate He2s ~$119/a piece
-Rockford Fosgate Power Punch Amp ~$475 (extra $75 for an extra 2 year warranty...
1000Watt
all i need to get after this is a box from this sound place in town (right?)im gonna get all the wiring i need from walmart for the subs and waht not, someone told me i need 4awg..and a 1.0 farad stiffening capacitor and a 100amp fuse...thats all at walmart right...it comes to around $1,300...:) .....i've attached pics for ur viewing pleasure
i've alwasy been a big fan of fosgate stuff. it really depends what kind of sound you are going for if this is the right setup or not. but heck, i wouldnt pass this up :)
Fosgate is a good choice, make sure you get 4 gauge wire and you might want to take a look at farad caps depending on how much bass you like. I have an 800.2 fosgate amp hooked up to 2 12" HE2 subs and when the volume is high and the bass hit's the light's dim. So depending on how bass happy you are you might want to get a farad cap.
I would check out some of the new PowerAcoustik if I was you. The woofers and amps are massive. You could get a dual 2ohm 15" for a $120 :thumb:
The rule of thumb is that for every 1000watts you are running you need one 1 farad cap. I ran the rockford bd1500 to 3 eclipse twelves and had two 1 farad caps and it worked beautifully. Later,
Cale
