Balleriffic1
- 113
- Oct 12, 2002
ah more help.......ive installed those windshield washers with the leds...they say that now i have to wire them to the "parking lamp"......i have a 420a...WUT DO I DO?/
Originally posted by 98_silvergs
Wire them to a switch that you can shut off and on. Go buy a toggle switch at an auto part store or something, they're like 3$. Run the black and red wires to it, run a power to the fuse box or the battery to give it power, and then ground the last connection
Originally posted by blitzedeclipse
those are the gayest things i have ever seen.
you will bled in with all of the pep-boy ass holes out there.:laugh:
, did you guys pick those up at the F&F sale at pepboys? j/k
Originally posted by forbidn1
question on the windshield washer nozzles. How do I adjust where the washers are spraying at? I tried to move the little nozzles but they won't move.
Originally posted by pc talon
You should be able to stick a pin in where the water comes from, and wiggle it around a bit, that is how I adjust OEM ones anyway.
Originally posted by halik
heres step by step guide for ya:
1. find a metal bucket or a can
2. insert the led washers into the can
3. unzip your pants
4. urniate into the can
5. pour paint thinner into the can
6. set the can on fire
!Originally posted by Balleriffic1
