Remote Starter
GROUNDFORCE
Oct 7, 2002
I am about to install a remote starter on my GSX to do this i have to disconnect and reconnect clutch wires i was wondering if anybody tried this and if its safe to do? (The reason you disconnect the two wires and connect them together is so that you dont have to depress the clutch to start the car) I am also going to work my turbo timer into my alarm so when it turns off the car the alarm arms.
My problem is my brain module from my starter won't learn my tach readings, the manual says i can also link the wire to my ground wire on one of my fuel injectors,
The problem is both my wires on all 4 of my injectors are puttin' out close to 14volts each, so i actually have 2 positives and no ground, don't ask my me how it works but my car runs perfectly, i'm just really confused about the ground, and gettin' my starter module to work
