voltmeter install
sids
386
Jun 24, 2002
<img src="http://www.eclipseworx.com/diy/voltmeter/1.jpg">
1. Remove the seats because its a lot easier to remove them than to work around them. Remove the center console.
<img src="http://www.eclipseworx.com/diy/voltmeter/2.jpg">
2. I've cut out the cigarette lighter, it has four wires, 2 are for the orange kight ring aournd it and the other 2 are for the actual lighter.
<img src="http://www.eclipseworx.com/diy/voltmeter/3.jpg">
3. I got an Autogauge Voltmeter, Its made in Taiwan but looks good, it works and has a warning light if ever voltage drops below 11.5v.
<img src="http://www.eclipseworx.com/diy/voltmeter/4.jpg">
4. This is the messy part, you have to cut away a lot of material from the console.
<img src="http://www.eclipseworx.com/diy/voltmeter/6.jpg">
6. No turning back here.
<img src="http://www.eclipseworx.com/diy/voltmeter/7.jpg">
7. Constantly check for fitment, the last thing you want is to cut away too much material. When you can force it through the hole, its time to stop, it should be nice and tight.
<img src="http://www.eclipseworx.com/diy/voltmeter/10.jpg">
8. I use terminals at both ends because I know this isn't the last time I will take out the center console
<img src="http://www.eclipseworx.com/diy/voltmeter/12.jpg">
9. Better shot with no flash. careful not to let the suckers touch any metal, I had the cig lighter power terminal touch something, sparked and I blew a fuse.
10. All assembled up and ready for testing. The meter should read 12.5 - 13 at volts at idle if your alternator is is good.
<img src="http://www.eclipseworx.com/diy/voltmeter/14.jpg">
11. More bling bling for my dash.
looks great, if my sister is willing to dish out a few bucks for a air/fuel gauge thats where ill put it, considering it sort of looks factory and is free
