unglued lower steering housing trim
TalonR
115
Mar 4, 2003
Oceanside, California
I have a question....my dash is coming unglued...or whatever hold it on....in just some seam areas.....like on the lower part of the dash.........what would be the best product to put the dash back in place
i am having this problem too... i was thinking maybe some high temp silicone or even super glue... a small piece of my center consol was lifting so i used super glue and it's holding fine i'm just not sure of the long term affects florida's summer heat will have on it...
Mine did the same thing on the bottom part when I had it off for installing some stuff. I just got some liquid nails, that PL400 or whatever it is, put it on there, and clamped it over night. No more problems :)
I really dont have anyway to clamp it though......I will have to try to rig something up to keep it pushed in.....Here is a pic of where it is lifting
If the bottom panel is the problem you are having, just unbolt it. I had mine off already, so it was easier, but the liquid nails will fix it for sure.
