I think i'm running a little rich.
Logue
408
6
Sep 27, 2003
Tuckerton, New Jersey
I logged today only my second time doing it so here it is.
14 pounds, 93 oct., 60 degrees outside. on minimal mods. intake, 1st gen bov, 1st gen head swap, and tb swap.
what do you guys think. i think i'm running a little rich at wot. if i am running real rich what do you guys suggest to fix the problem. i think i should have just done a 3rd gear pull but i didn't so here is this.
1st gear
3716 5 deg .98
4208 3 deg .98
4732 8 deg .98
5188 9 deg .98
5672 12deg .98
6180 18deg .98
6516 19deg .98
the o2s dipped to .92v when i shifted into second
4776 38deg .92v
2nd gear
4884 10deg .98
5064 11deg .98
5264 12deg .98
5444 13deg .98
5572 14deg .98
5780 16deg .98
5916 17deg .98
Looks rich but you need to do a third gear log. Do that and post the results..
your running like most stock cars due which is rich, turbo models run pretty rich out of the factory, you could lean it out with a s-afc (super air fuel control) but i would consintrate on other mods frist as leanning out your curent set up will not give you much more power.
