Quote:
Originally posted by 95GSXracer
Many people that think the boost dropping as rpm goes up is because they are outflow the turbo are actually see the WG blow open. I did the experiment, search this site for a thread named wg blowing open info for an experiment I did to confirm this
Hope that helps.
This is VERY interesting and not something I've heard discussed before. I have a big 16G and ported Evo O2 sitting here ready to go in and I just bought a 34mm WG valve. I really, really don't want ANY boost creep so I was going to install the 34mm. Are you saying it is a bad idea? I wil NEVER run more than ~20psi and the car will live 99% of the time on 91 oct at ~16psi. Will I still experience the WG opening and dumping bost with the 34mm valve at that level of boost?
Thanks!
Rob
