Confused about rear 02 bypass schematic and construction
Eastwood95
642
3
Feb 10, 2003
Youngstown, Ohio
Ok, I'm looking into bypassing my rear o2 and after some searching and reading I'm still a little confused.
The link in the tech guide is pretty straightforward:
http://www.dsmtuner.com/forums/showthread.php?t=221951
But his diagram doesnt match the actual pictures. In the diagram he has the capacitor and resistor in the opposite spots. The diagram shows the resistor first, then the cap at the end of the blue and white wires. But in the actual picture, he has the cap hooked up first, and then the resistor at the ends.
I looked at vfaq....
http://www.vfaq.com/mods/O2bypass.html
And the diagram matches the actual pictures from the tech write up.....
I'm assuming the vfaq and the actual pics from the tech article are correct....
AM I RIGHT?
