View Single Post
Old 04-13-2003, 05:18 PM   #42 (permalink)
allwheelTSI
Proven Member
Region: Southeast
Classifieds Rating: (0)
Reputation: allwheelTSI is more helpful than not
Quote:
Originally posted by cadesigns
ahm, possibly a wrong thread issue but its not one at the top....
would anyone know anything about converting a 1.8l nt into a 4g63t...?
swap the whole front end maybe... ? Is that ecu similar ... the same....? who knows...
also... im a newb at this what is the difference between 6/7 bolt motor and what does this mean when doing the swap.... how would i identify a 6 or 7 bolt motor
thanks!
with the 1.8 to 2.0t swap,you'll need a donor car: wiring harness,bottom crossmember(the one the points where the car is going),tranny,axles,ecu,the motor and every turbo related component on the car. theres probably more,but thats all that comes to mind at the moment. look around on vfaq,it'll tell you the difference between 6 and 7 bolt.
____________________________
Gerald.
Offline
Sponsored Links
