Installing a Greddy Fuel pressure gauge?
Awdboost
374
May 17, 2002
Arlington Heights, Illinois
I'm getting a Greddy Fuel pressure gauge and was wondering if there is any VFaq or a site you guy know of that has an example of the install.. Also what I need know about installing it and anything that need to be told. I just want some info before I go ahead and install the gauge.. Thanks guys.
If you installed any other guage you can install a FP gauge. Just make sure you de-pressurize the fuel system before installing the gauge unless you like fuel spaying all over you.
Later,
if its an in car gauge,you will need to mount the sender in the fuel line which requires a threaded banjo bolt at the return fuel filter. B&M sells the kit you need for $30. thats what i used. after that, the *gauge* install is pretty simple.
awsome I did know you could use the B&M one. Thanks alot. I have one laying around.. :D Look like this should be an easy install. Thank you guys for the help.:D
