Swapped out the engines
well, it wasn't all that bad, I had a wrecked 90 Laser RS-T and a 93 Eclipse GS with a 1.8L, we pulled the window, dash and the entire wiring harness, the worst part was getting the harness in and out, after that I just slapped it all together and troubleshot till I got it running right. The only real problem I'm having is this whistling sound, I can't find where the hell its coming from. might be the turbo?
it's most likely a boost leak of some sort. i'd double check all your clamps and piping.
