supergoat
- 1,035
- 2
- Jul 29, 2002
Ok, I made the conversion. I plugged in my palm pocket to see some readings and my injectors are reading 99% for low, mid and high.
Also I got an "Injector Circuit" error code. It was because I forgot to plug the resistor pack harness back in.
So I cleared it. The car finally started.
But the code remained. Any reason as to why? Perhaps I'll just have to disconnect the batter instead of clearing the codes via my palm software.
Also, how can I make certain that everything is hooked up correctly, electrically. Are there any tests I can do to make sure all my computers wires are ran correctly. I'm sure they are but I would still like to make sure all my connections are correct.
Thanks!
But the code remained. Any reason as to why? Perhaps I'll just have to disconnect the batter instead of clearing the codes via my palm software.Also, how can I make certain that everything is hooked up correctly, electrically. Are there any tests I can do to make sure all my computers wires are ran correctly. I'm sure they are but I would still like to make sure all my connections are correct.
Thanks!
