I have a 95 eclipse RS and i also have the TD05H turbo.
guy1innc
30
Aug 19, 2002
I need to know what all I would need to get for this turbo to fit on the 2G eclipse...i also have the turbo manifold from 1G eclipse.
Sure you can use that turbo, but it'a a piece. You would need a custom manifold because the other is from a 4g63 and will not bolt up. You do need to read up a lot more on the subject though. Your going to need a lot of other parts.
I would like to get my motor ready for the turbo..what else should i do to my engine to prep it up to handle around 350 hp
so i wouldnt need to replace my intake manifod or my bottom end? what about underdrive pulley or cam gears throttle body?
The rods and pistons are the bottom end. What bottom end are you thinking? Cam gears, throttle body and intake mani will only increase power, you dont have to buy new ones, but it will benefit from the turbo.
You also don't need to rebuild. You may find that the 420A will handle more abuse than you thought.
