injectors in but manifold bolt broke!
birdman
83
Jul 16, 2002
Newark, Delaware
i finally got my 415cc injectors in. the s-afc is going in wed just to lean things out a bit becuase i am running way to rich! i need to urgrade to s-fmu also a bolt broke on my exhuast manifold which sucks so its barley building boost past 6 in third gear but it should be getting fixed on wed. car sounds like a poop turd with that leak.
Hey bro don't go crazy with that SAFC wait till you have the sfmu in there. If you lean out too much on that safc it's going to bump your timing sky high and you may knock or blow the engine. You have to be careful with devices that fool sensors. I would get the SFMU in first so you can lean your idle and go with a smaller rise rate disk for boost. Then you will only have to lean a little bit on that safc.
