baxsom
- 480
- 5
- Jul 10, 2004
san antonoio,
Texas
I want to install bigger injectors so I can raise my boost level
it has the stock injectors and rails installed and currently running at 10psi
i have a hahn stage 2 in with everything that came with it
the only thing i have done to the turbo system is install a greddy spec II controller
i keep reading about SAFC and SFMU changes before I can go to bigger injectors
i am reading that the afc changes air fuel and fmu changes fuel pressure
my gauge says that idle fuel pressure is 40psi and under boost it goes way up
i see posts for apexi, greddy emanage etc
please someone tell me what changes to the car I need to run bigger injectors
the norm on injector size and what brands should i look for
thanks
thanks
