clutch upgrade
jdm93dsm
171
Jun 21, 2003
im wanting a new clutch and probably more performance. i was looking at the act 2100 but its an ass raping for the price. i have a nt so i was wondering if the turbo 1g dsm had a better clutch and if it could fit my car.... alil performance at a low budget. i dont plan on racing other than lil street fun and having a better running car than the rest of my buds, LOL. if there is another clutch worth checking into please let me know. and also the info on the turbo dsm clutches. thanks.
edit
I was also wondering w/ the turbo clutch if i would need the flywheel from the turbo or another recommended flywheel. thanks.
I think you can get away with using part of a fwd turbo bell housing case. You would need the part of the case which bolts to the block. I would think the bearing races and everything else inside would be the same so it should be a simple swap, although just buying a turbo tranny would be even simpler. The only problem then is you won't have your shorter gear ratios found in the non turbo tranny.
does anyone know anything about this?
from nj.. some kid who always come to race in newark
is runnin lows 13s...
with the stage 2 hahn racecraft turbo kit.... some motor work too has to be
let me tell u this car is sick.... 420a engine too
he shoots fire when he switches gear...
that shit aint bad for a 420a
