Well if you are gonna do it, do it right IMO. So if I were you, I would replace the valve cover gasket along with the spark plug hole gaskets, and the half-moon cam cap on the left ( drivers side ) intake cam. If you do not take off the intake manifold then you dont need to replace those. If you do take off the intake manifold, try to take it off from the lower half of the manifold so that you only replace that gasket. Other than thay just the headgasket is all you need.
Hope this helps and good luck!!!!
