Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 420A DSM Tech > 420A Bolt-on Tech
420A Bolt-on Tech Intake, exhaust, ignition, fuel system, cooling, etc - specific to 2G N/T DSMs. New Members must limit their 420A tech posts to this forum.
Reply
LinkBack Thread Tools
Old 03-23-2008, 07:11 PM   #1 (permalink)
New Member/Lurker
Boostin95RST's Avatar
Region: Midwest
Classifieds Rating: (0)
Reputation: Boostin95RST is an unknown
about 7-10 miles to the gallon
ok i have a 255lhp fuel pump and 450cc injectors and a sfmu. and this thing is eating gas like it was a beafed up v8. i have no clue what the problem is. i really dont know how to adjust/tune the sfmu. i am also getting a real strong smell of gas from inside the car, and if i put my hand on the exaust tip my hand is black after like ten seconds. another thing that you might need to know is i dont have a downstreem o2 sensor due to not having a cat. its in the mail on its way here, i dont know maybe that will help..... please help me guyes.
____________________________
A.Edge
Offline
Related 420A Auctions
Old 03-23-2008, 07:13 PM   #2 (permalink)
New Member/Lurker
Region: Midwest
Reputation: slowred96rs is an unknown
Your fuel pressure is way to high. get a good FP gauge, and turn your static FP sown to around 16-20 psi it all depends on the car as to where the sweet spot is. (the bleeder on top of the SFMU is used to lower FP). you also need to make sure your running the correct disk/ring combo in the SFMU, your also going to need to adjust the screws on the side of the sfmu to get the FP to top out at the correct amount, and not keep raising your FP and such. your just running way to high of a FP right now. how is your fuel system setup other than the 450's, 255, and sfmu?
Offline
[posts] Reply With Quote
Old 03-24-2008, 01:29 PM   #3 (permalink)
New Member/Lurker
Region: Midwest
ok i will try that, i need to get the guage first. i honestly dont know anything else about the setup. i am kinda new to this whole thing so im just trying to figure everything out.
A.Edge
Offline
Old 03-24-2008, 04:00 PM   #4 (permalink)
Proven Member
Region: Tri State
Reputation: RSTeclipse97 is an unknown
I think you need somewhere around a 4-1 disk or a little smaller. If you know what lb they are say 38lb or so you can go to vortechs web site and look at the calibration disk they have or even call them and they will probably tell you which one you need. And as mentioned above to much fuel.
Boosted 420A
Offline
Old 03-28-2008, 12:29 PM   #5 (permalink)
New Member/Lurker
Region: Midwest
sounds good. i will check that and give them a call. i dont have the disks, this kid sold me the sfmu and it was in his eclipse with the same setup so i just figured it would work.
A.Edge
Offline
Old 03-28-2008, 12:34 PM   #6 (permalink)
Proven Member
sniperelite's Avatar
Region: Midwest
Reputation: sniperelite is an unknown
Another thing to check is your lower injector seals. Those go bad after a while and can lead to gas leaking under your hood...possibly why your smelling gas. You can get the OEM seals at any mitsu dealer for like 6-8 bucks.
Offline
Old 03-28-2008, 10:06 PM   #7 (permalink)
New Member/Lurker
Region: Midwest
i dont think its leaking any gas, the only thing i got leaking is my oil return line, but i am going this weekend to buy parts for that. thanks though, thats a good thing to know
A.Edge
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
got a used act 2600 guy say it has 10 miles on it girlpower92 Drivetrain Tech 6 06-25-2005 01:08 AM
ONLY getting 11.6 Miles per Gallon??? HELP Brandnuflavor Newbie Forum 10 05-26-2005 06:27 PM
Turbo using up 1/4 tank of gas in 10 miles! cine135 420A Turbo Conversion 9 03-26-2005 10:52 PM
how many miles per gallon do u get? lowridin2g Newbie Forum 16 09-29-2003 05:21 PM
new car, 10 miles to gal., no power forcedfedgsx Problem Diagnosis 6 05-02-2003 11:29 PM
Page generated in 0.12508893 seconds (73.89% PHP - 26.11% MySQL) with 10 queries
© 2001-2007 SPEEDtuners Network, LLC All Rights Reserved
We recommend the Firefox browser. Get
