Flybiyou
- 304
- 3
- Apr 8, 2003
somewhere,
Illinois
I have searched and didnt find what I was looking for. Befor you do the test how do you know if the valves are all shut. Does anyone have a picture of where the crank is supposed to be set at. Also I have the 264/272 combo so will the valves all seal or not.
I tested the turbo to the pipe before the elbow and its fine. So I hooked it up to the elbow and pluged the hose from the head to the pcv valve,boost controller, and I dont have any vacume lines (removed EGR) is there something else I am not pluging that I should. I can build pressure but it goes out after a few seconds and I can hear it coming from the exhaust side of the head (manifold is off the car).
All in all where is the crank supposed to point so the air will not leak by the open valves.
Thanks in advance and for reading all this.
AJ
AJ
