You can fiberglass!
Ok I am turbo my car, and I needed a spot for my boost gauge. I wanted to go someplace new, and I saw a place on my dash I liked and seemed to be good for me. I took some pieces of cardboard (from a normal box) and cut out a small cutout of the shape I wanted the front of the pod to be. I then cut a small support from the top of the front face to the back of where I wanted it to reach. I covered the two pieces with some old t shirt material (I think cotton/polyester). Mixed up my home depot bought fiberglass resin with its hardener and dipped it in. Then I left it under a lamp to speed up the curing process. Next I added more cloth to make the sides of the pod. I redid the whole fiberglass process for the sides. Then again I did the whole pod over in fiberglass to acheive an equal layer all over. Next, I took out some 220 grit sandpaper and worked down the high peaks of the fiberglass, and used a razor to chip off parts that were too big to sand. I left the fiberglass overnight to fully harden and cure. The next day, I covered it in bondo, trying to make it smooth as possible. Sanded it with some 400 grit paper, which really did nothing. I stopped sanding and just used my razor to cut off any peaks in bondo and fiberglass. I rushed the process and it came out not so bad... I did not have any primer, so I used white spray paint, then tried to sand, and I was going nowhere with my 400 grit paper. I abondoned the project for a few days. I got some black primer paint from walmart ($3) and put 3 layers on, and this REALLY did cover up many of the small crevices in the workpiece. I have stopped working on this part as I need to get more sandpaper to make this smooth as possible.
Heres what you need to fiberglass:
old shirt
some cardboard or pieces of wood or plastic
fiberglass and resin
bondo
assorted sandpaper, I would start with 40-80 grit next time I do this. Never above 120 on the fiberglass. start with 100 grit on the bondo and use some extra on the piece and just take off what you didn't use afterwards.
primer - to cover up small crevices and defects
paint - whatever color ## interior is
heres pics. you can see the old shirt and the cardboard in the first 2.
I have all the supplies laid out
DO NOT USE STYROFOAM as your mixing place. it melts under fiberglass. I made this mistake and you see the results. Make sure you mix the fiberglass and hardner well, and I like to use extra hardner, less working time, but faster results.
Heatlamp and a plastic bag to protect the floor
some more assorted pics.
will add the final result installed after I put it in the car. Dont let the cardboard fool you. This pod is harder and more durable than any ebay pod you can get, and it is custom. I dropped it twice already outside on pavement, no damage other than a paint chip. my girlfriend also "accidentally" stepped on it. nothing broke
tips:
more hardner = less work time but faster hardning time
no styrofoam, it melts under the fiberglass
use some ventilation, I did this indoors and it smelled bad.
use a dremel to keep the hole for the boost gauge big enough at each stage.
I used hotglue to hold the cardboard pieces together and to attach the cloth to the cardboard.
pics are in reverse order, start from the bottom and you can follow my guide.
there were no pics from the bondo stages on, as I did not have any battery left on my phone.
the black stuff is just because the shirt was a dark blue, and my phone did not capture the blue but did get the darkness. If you use a white shirt, you will get brighter results :p
good luck, pm me with any questions.
