Quote:
Originally Posted by 99GSX Swede
There are quite a few threads on alcohol injection already. But anyway, yes you can run alcohol injection just fine as long as you get it sized properly. I run a 50/50 (distilled water/denatured alcohol) with stock 450 injectors and 19 psi boost on a FP Big28 with no timing being pulled. Before the 50/50 injection I was only able to get about 15 psi on my stockers.
Do you run a dual stage kit or a single stage? I am going to be purchasing a kit within the next 2 weeks to help with the stock SMIC. I'm not sure exactly which way I am going. I wasn't sure if one nozzle before the SMIC in the LICP would work, or if I should go with one after the SMIC in the UICP . Either that or a dual setup.
I have heard that putting one before the SMIC is worthless because you are wasting the cooling effects of the SMIC and should inject directly after the SMIC. But, I think I'm weird trying to run the stock SMIC.
