crankshaft timing sprocket
YoYo_4G63
187
4
Sep 5, 2008
Carolina, Puerto Rico
So i loose the bolt, how now i remove the crank timing sprocket? With a prybar?
I did the drill method to the oil pump and no leak there. Anyway i've changed the crank and cams seals, let's see how it goes.. thanks all for thr help
Leaks can be pesky. Are your balance shafts eliminated? If so, I know a lot of people have issues with the balance shaft idler pulley hole leaking. Some rtv usually helps in that area
Wasn't from there, was from the crank seal:cool:
Btw. Tq. the crank bolt was a pita, until i getto fab a bar with a 1x1 square tubing. Now is fine torqued at 80
Next time just put the car on the ground, put it in gear and torque that crank bolt. This does NOT work for taking it off as you're turning CCW then and you risk turning the motor slightly CCW which isn't a good idea. If anybody thinks this is hard on the transmission just think about what 400ft lbs does compared to the 100+ you're doing to tighten that bolt.
Turning a motor CCW is a bad idea? I thought you were supposed to rotate the motor CCW when doing the timing belt.
