GSX_TC1's 91 Galant VR4 #550/2000
GSX_TC1
2,754
23
Nov 29, 2007
Houston, Texas
Pauter Rods, Ross Racing Pistons, ARP everything polished crank, Clevite 77 bearings
Cometic Head gasket, 3 angle valve job, Ferrea stainless valves, double springs, titanium retainers and 3g lifters, FP2 cams, HKS cam gears, and power enterprise kevlar timing belt.
Spearco 2-216 Front mount
New power steering rack
Redline fluids for the Trans, transfer case and rear diff
ACT Streetlite flywheel and ARP flywheel bolts
Fluidampr with ARP crank Bolt
All new gaskets, bolts, washers, Orings etc etc
new OEM Mitsu Clutch master and Slave and throw out bearing with braided clutch line
new OEM Mitsu Alternator and Starter
new OEM Mitsu belts, Walboro 255 fuel pump, OEM 0/2 sensor, thermostat, fuel filter, and spark plugs.
DSMlink version 3, speed density parts, and HKS BOV
STM external oil cooler kit
new OEM lower cover, zaklee upper clear cover, and FP2 cams with my powdercoated Valve cover
looks good bro! get too assembling!
Looks like a good start!
Two questions for you though: What's the part number for the K&N filter? I'm fairly certain the part number that comes up at my work is for the 420a :(. And what's the part number for the B&M oil cooler?
Looking good mike. What are your goals for the car?
That knn air filter is for 1g/vr4 and the 420a is a rectangle shape
Looking like its gonna be a pretty good build. What turbo?
For right now, EVO3 big 16G then later on hta68
Will do! =D
What are the springs on the 02 housing for?
Lol what springs? I don't have an o/2 housing pictured.
Oww! Your new cams are laying on the concrete!
Lol I placed them there gently
My goal is to have a 500 hp daily driver
Seeing all of those nice brand new parts has me drooling. Nice build
Thanks man
thats about what my goal is for while the GSX is my daily... once i get the talon back on the road, ill be going big!
2nd picture.
Springs on what appears to be a external wastegate connecting to a exhaust piping that has a 2 bolt flange on the bottom (I thought the flange connected to the down pipe which lead me to believe it was an O2 housing of sorts).
Ahh ok yeah man that pic was taken when my motor was in the showroom of the shop that built it for me. They had that setup on there for display purposes.
Did you put this in the hangout on purpose or....
Lol I always post stuff in this section on my car, you know this Scott =)
^^ ha!
Can't wait for this! I've been loving your car for ages.
Thank man! =) the build shall continue and lots more to come
Some one has to much money! Its going to be one clean engine all around when your done. good job man, Now where's the pics of the car?? :sneaky:
I always post pics of my car so I'm sure people are sick of seeing it all over the place by now LOL
Sorry, I meant oil filter. Should have been more clear.
Still curious about the B&M cooler as well.
the oil filter is part number HP-1005 from K&N
and heres the link for the 1g DSM oil cooler kit
STM OIL COOLER KIT | 90-99 DSM
got another piece to add to the build.
FP 4inch intake non recirculated, with massive K&N filter and a miracle reducer coupler that allows that huge intake to fit onto my evo III big 16g =)
Some more Progress pics, =)
On the lift
this motor got me from Cali to Ohio, then cali to AZ then Cali to TX =)
Before
pressure washing
After
about to put on the ACT streetlite, with ARP bolts
old clutch back on, now to put it back in next.
seen all these builds of galants is making me want to get into mine more and more. cant wait so see how she turns out. good luck man.
Hey thanks man! =) you coming to the shootout?
Ok the new Motor is finally in =)
So clean and fresh
New OEM Mitsu Slave going on
stainless bolts for the oil pan
New OEM Mitsu Starter going on
the old motor lurking in the distance
New OEM Mitsu Clutch master going on next
