Closed loop vs. open loop mode
I'm assuming your talking about MS?
Closed loop is best to run during part throttle through 100kpa; Turn off when in decel and in boost. Closed loop changes the speed density calcs to obtain the correct AFR. Open loop is without correction from "a" sensor.
