- Thread starter
- #26
dsmdeliveryboy
- 2,051
- 5
- Aug 14, 2007
Medford,
Oregon
I dont know if this is what you meant by adjusting the master rod, but i was having similar issues with my car and i had to adjust the rod on the master very loose to get it to bleed properly and once i had pressure then adjusted it back out to tight on the pedal, I read your post and wasnt sure if you had done this or not, something to give a try... i had replaced everything too and could not get pressurte untill i did this, backed off the lock nut and loosened the rod it alowed the master to bleed properly
Sorry haven't had internet
Still no success
Haven't had a lot of time to work on it though either
I'm gonna order a extended slave tonight and rebleed the whole system.
this one just has me stumped, I've never experienced anything like this.
