Spec Clutch
mace01
48
Jan 17, 2003
Geneseo, Illinois
Hey Dsm'ers,
I'm pretty new to this drivetrain stuff, but my stock clutch on my 90 Talon Tsi is going out, so I'm looking at buying a spec stage I or stage II. First of all, I'm probably shooting for around thirteens eventually, so which clutch would be the best mix of streetability and being able to hold well for a low thirteen's maybe high twelves car.
Second, do I need to buy anything besides the new clutch. I've heard of people getting new flywheels or having their old ones resurfaced or something. Can I get by with just the new clutch, or is this project going to end up costing a lot more than 3-4 hundred dollars.
Thanks,
Jeff
I highly recommend resurfacing the flywheel, but all you need really is the clutch kit (plate, disc, bearing, pilot)
Even if you buy a new flywheel, you should still make sure the step is to specifications (.610??? someone confirm this)
Also if you are goin to 13s, go get a SPEC Stage 3 (6puck).
I've got one, and the pedal pressure feels almost stock! The clutch bites hard as all hell too. It is good for over 400ft/lbs of torque.
There will be some getting acustomed to the very short "play" area between disengaged and fully engaged, but it is real easy.
