EagleTalonTim
- 830
- 13
- Jan 10, 2007
Brighton,
Tennessee
I am rebuilding my 6 bolt and have gone with standard bore Manley pistons, stock crank, clevite bearings (standard size) and standard size Manley H-beam rods. I have started to install the pistons one at a time after gapping the rings per cylinder and cannot turn the crank by hand at all with just 3 pistons installed. I could with 2 by grabbing onto the counter weights on the crank, but it was still tough. Is this normal? I can turn the crank with a ratchet without a tremendous amount of force but if I recall correctly, the last engine rebuild I did reusing all stock parts, it was much easier to turn. When I turn it with a ratchet, it feels like the pistons are having a tough time moving up and down the bore. I did hone it before installing the pistons and the PTW clearance is within spec for the Manley pistons. Please advise before I continue with the last piston.
The rings are what came with the Manley Pistons. They are gapped at .21 and .25 as what i have found to be a good setting from about a month of research....
