NHerron
- 2,776
- 65
- Nov 5, 2011
Missoula,
Montana
...These expensive plastic timing belt covers, I swear
First off, this is a 6 bolt in a 2G bay.
I have seen all the threads here on the oil pan bolt gouging and crank timing plate rubbing the belt on the inside. But I'm having problems with the belt wearing on the OUTside towards the plastic cover. It's fraying the cords a little bit and the teeth now have a slight angle to them.
Before the tear down I marked the belt with a red paint stick 7 inches long and drove about 20 miles. Now the red has worn off on the teeth portion, but not the flat area. I used every bolt to secure the cover as well as the top cover so nothing could get in. The belt also rides perfectly centered.
So I pull off the timing cover expecting to find a nice gouge in the plastic but it wasn't that bad. I only found ONE spot where it looks like it was barely touching, and I couldn't even feel with my finger.
So is that the only thing to blame here or???
Thanks pictures attached. Please comment
