92AWDHX40
Supporting Member
- 14,459
- 2,668
- May 22, 2007
Kalamazoo,
Michigan
Simple enough design.
I have one sitting here on my desk, but I believe it's live inventory, not a sample, so they probably wouldn't let me send it out for free to be tested.
I'm curious though; how would you go about testing something like this?
The inline blowers that I sell range from 140 CFM to 240 CFM depending on length and diameter. I have no clue what kind of CFM one of these Ultra Cool fans moves.
I only have basic measurements of it. It's roughly 11.625" in diameter and an overall thickness of about 2".
Directionally vaned rotors work similar to these?
TCE offers directionally vaned rotors. I was told they make a difference over a traditional OEM straight vaned rotor.
I couldn't see 1G or 2G swirlies do much of anything.
I'm trying to remember the supercar I saw it on... but one of the newest hypercars has a piece that bolts to the outside surface of the wheel that grabs air and forces it thru the spokes of the wheel... Straight thru to the vanes of the brake rotors. It was pretty neat.
Also I read that titanium is widely used. As titanium is terrible at heat transfer. They put a spacer block of titanium between the brake pad and the brake caliper to help keep the heat in the rotor and pad and not in the brake fluid.
Also I'd swear I just read somewhere that a newer supercar has fluid cooled brake rotors. Positive of it.
The first thing I was thinking when I saw those is are they going to add a lot of rotation mass? If you're having to spin four fans on your wheels, that's gonna require a lot of extra horsepower just to turn them at speed, no?
Not the ones I saw. I think the ones I saw were on a Konigess. er However you spell that company. Maybe Porsche. I forget. It was actually a dish that bolted on to the face of the wheel. that stuck out slightly farther than the edge of the rim. So as it drove down the road the leading edge would grab passing air and cram it thru the center of the brake rotor. Real neat.
I'm not saying they way a lot, I'm saying I think they would take horsepower to turn quickly because of the air they move. For example, I work on diesels for a living, and those massive fans turning 2-3000 rpm takes a lot of horsepower. These are much smaller, but there's four of them. I'm just thinking that might add up when your at speed.
