90 awd turbo eagle talon modded 4s!!!
spininall4s
Jan 30, 2008
south, New Jersey
Selling due to me moving to the west coast i have two cars and one has to go... car runs very strong it used to be my daily ...its been maintained meticulously oil changes every 1500 miles all fluids recently changed (rear, tcase , trans) cars in great shape very fast !!! car is currently running on pump gas but is meth injection ready. car has never been tracked or been on a dyno but if i had to guess it makes around 450 -475 whp on pump easy with the meth it would easy be 500+ whp $5400 obo...motivated seller...all offeres reviewed ..not looking to give out joy rides...CASH ONLY no TRADES..MONEY IN HAND FOR TEST RIDE... serious buyers only please thanks... car is already fast and functional no suprises ...car shifts good and tune is on point ... buy with confidence ..south jersey area
90 Eagle Talon Tsi
AWD TURBO
TAN 5 speed Manual
130k body
8.5k on motor
Head: hks 272 intake and exhaust cams/ BC valve springs & retainers/SS valves/ Gates Racing Kevlar Timing Belt, 4 layer mitsu metal head gasket, arp head studs
Block: Ross Pistons 9.0 to 1 / eagle rods/ acl race bearings
Turbo: Holset HX40 Pro 6 blade billet wheel/ Halman manual boost controller/ 2g manifold with Tial 38 mm wastegate/ HKS super sequential BOV/ Custom O2 housing/ Custom 3 inch downpipe wrapped in exhaust wrap/ Magnaflow muffler/ 3in extreme psi intake with K&N filter
Fuel: 2x Walboro 255 hp fuel pumps (rewire upgrade)/ -6 feed & return stainless steel lines/Fuel Lab Fuel Filter / Aeromotive AFPR/ FIC 950cc/ Snow peformance 150psi meth pump with check valve/ Devils Own Pressure switch (meth kit installed but not wired in)
Electronics: Stewart Warner 40psi boost gauge/ Stewart Warner oil Pressure gauge/ AEM wideband/ AEM 5 bar map sensor (included)/DSMLink v2/RPM Digital Tach(shift light)/ Oil Temp Gauge(included)/ Taylor Race ignition wires/ spare ign coil
Suspension: Eibach pro springs/ Kyb AGX adjustables front & rear
Tires/Wheels: 17x7.5 rev wheels / Falken 615 rt
Transmission: ACT 2600 6 puck sprung clutch/ stainless steel clutch line/ Spare 4bolt rear (included) 2 spare transfer cases/ short shifter/ 2g shift knob
Misc: Battery Relocation to trunk/ Fluidyne Aluminum Rad/2x 12in slim fans/ Alpine ipod head unit/ pioneer 6x9 speakers in rear/ front speakers not sure of the brand (infinity)/ half a tank of M1 vp racing methanol/ spare throttle body/ spare uppipe /XS power 3inch core front mount intercooler/greddy catch can, spare coil, spare headlights, random couplers tbolts
Brakes: 2g twin piston caliper upgrade/EBC red brake pads/ Goodridge stainless steel brake lines/ EBC slotted front rotors
nobody wants a 1g that RUNS! no assembly required....i see some guys sellin theres dissassembled for 1000 less ...where else can you buy a low 11 high 10 sec car for under 6k
