fergulus
- 205
- 1
- Dec 18, 2007
Portsmouth, UK,
Europe
I am looking to find out the maximum airflow that you can push through 2.25", 2.5", and 3" piping. I see tons of intercooler setups with 2.5" pipes, but am trying to figure out at what lb/min each size will become a restriction.
I'm not looking for opinions, I am looking for the math to prove it as well.
. And its just good to know stuff. I would recommend if you ever decide to max your turbo's potential that you need to upgrade your size to 2.5".
.. i know. im tired. maybe can explain a little better for ya tomorrow.
... i want to ask you. if you can help me out in figuring this out a bit. i would like your input and a bit of help in the situation since you bring up a good point. how is it that you determined most dsmers by 7500 rpm's are hitting .5mach.. is it due to the fact that is what our motors create or is that just a general statemen and seeing where most fall under?) because like i said, the chart is not accurate for our real time instance with compressed air, the extra heat, and all that.. in my opinion when i eliminate some of the variable it will show that the intercooler piping can flow more air at the same mach number based on the fact the air is denser (under boost/ being compressed) and more air well in turn require less actual space. thus more air can flow.
