LocknessMonster
- 113
- 1
- Jun 19, 2007
Saint James,
New York
Ive never compared one side by side, but is the tps sensor on a 1g throttle body the same as on the evo?
It's straight plug and play, but its not going to bolt up.
it should work as everything is the same. they are the same size as a 1g, so unless you have a stock 2g your not gaining anything. and 1g's are cheaper. If on a 2g manifold you will have to port match the inlet of the manifold to the tb.
This is wrong.
An evo1-3 TPS is the same as a 2g TPS which is not the same as a 1g TPS.
