good day
As far as I know they do not. If you are swaping to a seven bolt from a 6 you will need to use the 6 bolt oil filter housing and get a new filter housing gasket.
they are differnt but they bolt up so you can use the air cooler off the 90 on a 7 bolt this is a common upgrade for 7 bolts. I just was un sure off a 1g 7bolt as for I have yet to own a 1g 7 bolt turbo. I have owned several 90s and a few 2gs.
the engine is 6 bolt always has its out of my laser but i need to know if i can block it or if i have to have that
this is my engine thats got dropped in
