tec_41
- 342
- 7
- Nov 23, 2008
West Bend,
Wisconsin
I'm doing the head gasket on a buddy's GS...He just had the timing belt and water pump done (why he didn't do this at the same time is beyond me) so that's not an issue. I'm trying to remove the head and have the front timing belt cover and timing belt off, as well as the valve cover removed.
I've searched relentlessly for an answer to this, but can't find it. I need to get the cams out to access the head bolts. Everyone seems to say you don't need to take the cam gears off to get the head off, but with the rear timing cover on there's no way that's possible. And to get the cam gears off while the head is in the car is a PITA because there's almost no access to the rear cam gear bolt.
What do you guys do in this situation?
). Or have some one block off the muffler (with a rag in their hand) and listen for exhaust escaping.
